Reinstalling Airbags
Wassup does anyone know hot to reinstall airbags? I know how to bolt it back on but will I need to take it to Honda after to reset the computer. Need help bad.
Re: Reinstalling Airbags (civicrtype)
You have to disconnect the battery to reinstall the airbags anyway. So whenever you reconnect the battery, the computer will reset itself. Disconnect the battery, bolt the airbag in, connect the wires, reattach the battery, start the car & let it idle until the radiator fan comes on. That's it.
Re: Reinstalling Airbags (94gsr)
the SRS unit needs to be reset to turn the light off - disconnectiong the battery will not do it. Which year/model are we talking? Were the airbags deployed? If so- depending on the year you need to replace the SRS unit.
Re: Reinstalling Airbags (fixhondas)
Fixhondas - good to see ya!
Would there be a reason why I didn't have to reset the SRS unit? Or am I recalling incorrectly, and I did, indeed have to reset it?
I am not 100% sure- maybe on older models disconnecting the battery might clear it But I know for a fact that at least 94 and up Accords and 92 and up civics must be reset through a procedure in the book with a jumper/connector.
Bad_dude
01-25-2011 07:10 PM
2000, 94, accord, air, airbag, airbags, bags, honda, install, installing, integra, reinstall, reinstalled, reinstalling, resinstall
