ITR 4-lug conversion
Old 11-26-2002, 06:55 AM
BigZ88's Avatar
Default ITR 4-lug conversion
Ok, if i were to buy the ITR 4 lug conversion, what brake rotors to i use when the time comes to get new ones? Also what pads? I just kinda want to know everything before i actually do this.
Old 11-26-2002, 06:58 AM
IN VTEC's Avatar
Default Re: ITR 4-lug conversion (BigZ88)
Probably the G4 Prelude BTEC or G5 Accord Wagon.
Old 11-26-2002, 07:16 AM
BigZ88's Avatar
Default Re: ITR 4-lug conversion (IN VTEC)
ok, that is what someone else told me, so i guess it must be true. Brian at fast brakes said something about a wierd offset so a slight mod to the caliper bracket might need to be done to center the caliper, what does this mean? bend the bracket?
Old 11-26-2002, 07:40 AM
IN VTEC's Avatar
You can't simply bend the bracket. It's 1/4" steel. You have to take a little material off the inside of the caliper bracket (thing the caliper sits in). It'll probably need 1 or 2mm of depth removed.
I say a little, but it'll seem like a lot when you're actually doing it b/c there's so much surface area to cover.
Old 11-26-2002, 08:18 AM
BigZ88's Avatar
well i guess thats not too bad.... might be able to do it here at work.
Old 11-26-2002, 01:22 PM
BigZ88's Avatar
anyone else have info on this?
Old 11-26-2002, 01:42 PM
10K2HVN's Avatar
Whats a ITR 4 lug conversion..?? because i want to get the 5-lug conversion but i never heard of a "4-lug conversion"....
Old 11-26-2002, 04:22 PM
IN VTEC's Avatar
Default Re: ITR 4-lug conversion (10K2HVN)
The '96-supeku JDM ITR's have 4x114 lug pattern.
The '98-spec JDM ITR's have 5x114 lug pattern.
Rotors must fit the lug pattern.
Old 11-26-2002, 04:30 PM
10K2HVN's Avatar
oh ic...
Old 11-26-2002, 04:33 PM
BigZ88's Avatar
I need info on this ASAP!!!!!! please.
Old 11-26-2002, 05:09 PM
eg6ajk's Avatar
the funny thing about ITR the rotors is that they are 4x114.3 but the size of GSR/SiR (10.3") brakes not prelude which are 11", so it means you need to look into redrilling GSR rotors or upgrading to 11" prelude rotors along with calipers.
now calipers are identical to GSRs, means that the pads should also fit
Old 11-27-2002, 05:21 AM
BigZ88's Avatar
Default Re: ITR 4-lug conversion (eg6ajk)
that is kinda contrary to what everyone else has said...hrrmm
Old 11-27-2002, 11:44 AM
fastbrakes's Avatar
He's correct, the rotors are 10.3 but in the 114 spacing. If the calipers are the same as the Teg then the mods need to the ITR (5lug) calipers is what you need to do to fit the Prelude VTEC rotors on there...
Old 11-30-2002, 07:11 AM
BigZ88's Avatar
Default Re: ITR 4-lug conversion (fastbrakes)
so is this worth it or not? am i goin to have to spend a crap load later to get new rotors when these go to hell?
Old 11-30-2002, 12:04 PM
Rob Dizzle's Avatar
either get gsr brakes
or get 5x114 itr brakes
dont bother with the 4x114 setup
rob1570
Suspension & Brakes
13
04-05-2011 03:45 PM
toohardtochoose
02-13-2011 04:11 AM
hovic
03-31-2005 10:45 AM
integra-modder
08-16-2003 01:17 PM
Quick Reply: ITR 4-lug conversion
