recharging odyssey pc680!! - Honda-Tech
Old 01-12-2012, 12:00 AM   #1
cibao2ner's Avatar
Default recharging odyssey pc680!!
i have a brand new odyssey pc680 and after 2 weeks its dead..i drive the car once every 2 weeks..last time i jump started it let it warm up and when i turn it off it didnt start again battery was dead...after been on the car for 1 month..the 1st 2 weeks it started up fine...
since its an agm battery what charger can i use outside the car to keep it charged...or should i use the warranty and get a new one..
cibao2ner is offline   Reply With Quote
Old 01-12-2012, 07:32 AM   #2
Default Re: recharging odyssey pc680!!
you're gonna need a new battery, since you killed it.
i would suggest getting a battery tender for it.
kyden is offline   Reply With Quote
Old 01-12-2012, 03:35 PM   #3
cibao2ner's Avatar
so im out 130 bucks..on a battery that i didnt get to use..
Old 01-12-2012, 04:03 PM   #4
Touching My Member
.Manny.'s Avatar
I've drained my PC680 a few times, but I made sure to buy the Odyssey specific battery charger and was able to bring it up to full charge every time. I've been told that they don't take too kindly to being jumped and that it can damage the cells (don't know how true it is).
I also brought a couple of other Odyssey batteries back from the dead. Good Battery/Tender to have in the garage.
.Manny. is offline   Reply With Quote
Old 01-14-2012, 09:46 PM   #5
uberEFtuner's Avatar
Well the battery charges when your car is running. So ANY charger will work. Its a deep cycle so you can kill it and recharge it for years! How far dead it is determine the life span of the battery.
A normal dead battery is a situation where the car doesn't start and the voltage is low lets say 12.0v-12.5v. You can do that many times. If you kill it very far 10v-11v its possible to damage the battery.
My stinger spv35 I have killed many many many many times. The last time it was way down to 9 volts. I thought it was ruined. But it came back!
Your battery should come back just fine with a standard 10A charger.
uberEFtuner is offline   Reply With Quote
Old 01-15-2012, 01:02 PM   #6
90sedan's Avatar
Make sure you disconnect the battery terminals if you are letting the car sit for long periods of time without running it, you won't run into issues with it.
90sedan is offline   Reply With Quote
wtb PC680 odyssey battery in o.c. 1fatcrxnem1 Southern California (Sales) 3 11-20-2012 01:31 AM
help my crx is having isses streetsold6teeny8 Honda CRX / EF Civic (1988 - 1991) 1 08-10-2010 10:47 AM
What battery mportbusta Drag Racing 10 02-06-2010 10:27 AM
Odyssey PC680 not holding charge nemore :( DarkBB4 Honda Prelude 8 06-12-2007 02:05 PM
FS: Brand NEW Odyssey PC680 Lightweight Battery B2FiNiTY For Sale 15 05-01-2007 08:03 PM
Tags
battery, capacity, charger, charging, drain, honda, integra, oddyssey, odysse, odyssey, pc680, problems, rsx, start, tender
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
