Are radiators interchangeable????
Old 06-24-2005, 03:39 PM
cloven's Avatar
Default Are radiators interchangeable????
Quick question: Are radiators interchangeable??? I mean, is a radiator just a radiator. For example, can I use radiator from a Ford or BMW in my integra providing proper mount and hose fitment?
Any help would be great!!!!
Old 06-25-2005, 06:51 AM
fabworxs's Avatar
Default Re: Are radiators interchangeable???? (cloven)
yes the concept of a radiator is all the same and most radiators are all the same. there is down flow radiators, crossflow radiators & there are doublepass radiators but they all work the same way....it all depends on what you can fit in the car.
Old 06-27-2005, 04:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cloven &raquo;</TD></TR><TR><TD CLASS="quote">... For example, can I use radiator from a Ford or BMW in my integra providing proper mount and hose fitment?</TD></TR></TABLE>That's too broad of a comparison. Gotta worry about 3 things:
1 - Physical mounting & hose connections, along with size & shape of the radiator. Can you make it fit? Are the hoses at the wrong corners?
2 - Cap. Some carmakers don't have a radiator cap at all. Many European cars like VW & Saab have a pressurized reservoir tank, & the 'radiator' cap is located over there on the tank.
3 - Heat load. If you pick a radiator that doesn't have enough cooling capacity, you're asking for trouble. This is more important than the other stuff.
CasperX
12-18-2007 02:34 PM
aasaa666
10-22-2007 08:15 PM
hondachris1994
17
04-09-2006 07:14 AM
SlowazzGSR
09-18-2003 10:51 AM
Quick Reply: Are radiators interchangeable????
