ok, when cold car runs fine, warms up= stumbling???
i have a dx bottom end with a 89 si top half in my 93 hatch. i had this motor in my crx before and the same prob was happening, when i first start it up its fine about ten minutes or so till its fully warmed up then its starts to idle higher and it will stumble when i first hit the gas to go. and it doesnt run as good. any idea what this could be? its done it in both cars i had. timing is good. ??
Re: ok, when cold car runs fine, warms up= stumbling??? (civicracer1993)
When cold, the ECU will rely on a base fuel map. When the engine warms up, the ECU will trim the fuel based on various sensor inputs. It might be seeing something from a sensor it doesn't like. Check out the TW, O2, TPS, FIV, etc, for starters.
Or, could be a vacuum leak from either a gasket or a ported vacuum system. Spray a mist of water around all mounting flanges. Visually inspect vacuum hoses.
