Question on cut engine harness?!
Old 01-28-2003, 08:49 PM
95hbMatt's Avatar
Default Question on cut engine harness?!
Found a guy that's selling a engine wiring harness..it has all the plugs to the motor but has been cut right when it's leaving the motor....the harness is from a 98 ls motor. I'm doing a 96 b18b swap into my 95 hb....can I use this cut harness and just splice on to where it's cut with my stock wiring harness that's on my sohc motor?? also, just for fyi i'm going obd1(using p75 obd1 ecu)...
Will the splicing be a pain in the ***? Should I just spend the extra money on a full harness.....if so, anyone have an obd2 LS harness for sale?!
also can an obd2 engine harness from a sohc nonvtec(d16y7) work also...
Old 01-29-2003, 11:11 AM
95hbMatt's Avatar
Default Re: Question on cut engine harness?! (95hbMatt)
ttt
thundernoodle
06-19-2012 05:58 PM
got00rice
05-15-2009 05:53 AM
prime-R
03-01-2009 12:17 PM
ShowtimesDC2
09-07-2003 05:53 PM
hondaspeder
07-04-2003 10:50 AM
Quick Reply: Question on cut engine harness?!
