Question about flucuating Volatages
Old 01-24-2005, 06:25 AM
groundedcivic91's Avatar
Default Question about flucuating Volatages
I have a VAFC so I can see the TPS and MAP volatge in the "Sensor Check" screen. That doesn't matter, but just helps to see voltage.
Now I know the TPS should have a volatage of .45/.5 Volts with the ignition on (Car not started) and the throttle completely closed.
Now if you start the car, and throttle completly closed as well, shouldn't the voltage still read .45/.5 volts?
-Confused
Old 02-01-2005, 09:59 AM
Default Re: Question about flucuating Volatages (groundedcivic91)
Bump for a confused soul
Old 02-01-2005, 01:42 PM
NJIN BUILDR's Avatar
I'm not sure what your asking.Is there a major difference on yours between started/stopped.
Glenn
Old 02-01-2005, 02:45 PM
Default Re: Question about flucuating Volatages (NJIN BUILDR)
The haynes says that the TPS Voltage should read somewhere between .45-.5 volts with the ignition on and motor NOT running and throttle completly closed.
Mine reads .48 volts with ignition on, and motor NOT running and throttle closed.
My question is, when you start the motor shouldn't the TPS voltage STILL read between .45-.5 volts at completly closed throttle?
Old 02-01-2005, 02:57 PM
My guess would be yes.What does yours read when its running?
Glenn
Old 02-01-2005, 03:37 PM
While its running, and at closed throttle, it reads anywhwere from .25 - .35 volts. and it flucuates, which is another concern I have. The voltage shouldn't flucuate when holding a constant throttle position(highway driving)
gabrielsousa
16
11-25-2015 10:02 PM
blackeg
Engine Management and Tuning
08-19-2013 05:30 PM
portenio78
09-02-2012 11:52 AM
skuded
11
12-15-2010 02:07 PM
crist488
08-28-2009 09:05 AM
Quick Reply: Question about flucuating Volatages
