Possible to adjust automatic transmission shift points? - Honda-Tech
Old 07-10-2005, 01:36 AM   #1
chris89's Avatar
Default Possible to adjust automatic transmission shift points?
My friend has a 95' Civic EX with the 1.6 VTEC and his engine will rev to 7200RPM but every time he nails it, it'll only rev to 6200RPM and shift. It's an automatic transmission. Is it possible to get it to rev all the way to redline without buying anything?
chris89 is offline   Reply With Quote
Old 07-10-2005, 09:00 AM   #2
superdupervtec's Avatar
Default Re: Possible to adjust automatic transmission shift points? (chris89)
There is a special tool, sort of like an allen key and with that you can adjust the solenoids on the trans, the good thing is that honda has them on the outside and they are easy to get at. You will need a manual to tell you which one is which and with that you can asjust how hard the trans shifts and how long it has to rev before it shifts up shiftos or downshifts. I saw the tool in ATRA (automotive transmission rebuilders association) or somthing like that magazine.
superdupervtec is offline   Reply With Quote
2000 Accord J30A1 Tranny Issue or Not? pmpate Honda Accord (1990 - 2002) 4 09-27-2016 12:52 PM
Possible Transmission Problem on 99 Accord thisismrjd Honda Accord (1990 - 2002) 14 06-22-2009 10:22 AM
Highter rpm stall converter for automatic transmission pureplayaz Transmission & Drivetrain 1 10-17-2008 11:15 PM
shifting problems, maybe the transmission Moshimoto racing Acura Integra 4 01-28-2005 10:52 PM
shifting Moshimoto racing Acura Integra 3 01-19-2005 10:10 AM
Tags
adjust, adjusting, adjustment, ajust, auto, automatic, civic, honda, points, prelude, ridgeline, shift, shifting, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
