Mugen Chip for B18C?
Old 07-09-2005, 07:32 PM
Bryro22's Avatar
Default Mugen Chip for B18C?
Im getting a B18C put in the Del in a few days using (p72) ECU and the shop im having install the engine said they can put a "Mugen" chip in it which increases redline, will run the engine alot richer, and allows for only one VTEC engagement that hits at 5700 RPM.
Is there such a chip? And I thought Mugen stuff was expensive. Their asking 100 dollars for the chip. Any information on this would be great. Thanks.
Old 07-09-2005, 07:50 PM
mtber's Avatar
Default Re: Mugen Chip for B18C? (Bryro22)
The mugen chip they are speaking of is a generic copy of the mugen ecu program.
Your gas milage will not be the greatest with a spoon/mugen/skunk program.
You would be best off with a stock ecu or looking into a Phearable.net program
Old 07-09-2005, 07:52 PM
mtber's Avatar
Default Re: Mugen Chip for B18C? (mtber)
By the way, b18c1 motors don't use "dual stage vtec".
They use one vtec engagement point.
Anything over 5300 rpms for a vtec engagement point on a b18c1 with stock internals is too high.
Old 07-09-2005, 08:10 PM
Bryro22's Avatar
its a b18c not a b18c1. B18C has two VTEC engagements. So you dont suggest i get the chip? Will it greatly decrease gas mileage...and what about performance...do these chips raise hp and torque numbers?
Old 07-09-2005, 08:24 PM
Bryro22's Avatar
I dont want to blow my motor the first day i get it installed so...
Is it a good idea to chip your ecu on a stock engine? (mine being the B18C)
Old 07-10-2005, 07:39 AM
been there done that
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryro22 &raquo;</TD></TR><TR><TD CLASS="quote">its a b18c not a b18c1. B18C has two VTEC engagements. So you dont suggest i get the chip? Will it greatly decrease gas mileage...and what about performance...do these chips raise hp and torque numbers?</TD></TR></TABLE>is it a b18c from an itr or sir-g? both only has one vtec engagement point.
</TD></TR></TABLE>no it's not. especially with a generic program.
Ferna_R
09-24-2009 10:45 AM
vizsual00
03-26-2003 02:35 PM
civicbro
02-12-2003 05:44 PM
Quick Reply: Mugen Chip for B18C?
