plug order on distributor for y8?
Old 10-06-2003, 06:00 AM
SOHC_MShue's Avatar
Default plug order on distributor for y8?
i was taking off my wires on the distributor and i forgot to remember where all the wires went on the distributor cap. Does anybody know the order for a d16y8 distributor? Also does the plug that plugs in farthest from the distributor count as 1 and then starting from the right go 2,3,4? or is it 1,2,3,4 starting from the left?
Old 10-06-2003, 05:45 PM
Esoterikos's Avatar
Default Re: plug order on distributor for y8? (SOHC_MShue)
the cylinders are numbered from the front (timing belt side) to the back (tranny side) 1-2-3-4, and almost ALL four-cylinder engines fire in the same order, 1-3-4-2.
Old 10-06-2003, 06:06 PM
SOHC_MShue's Avatar
Default Re: plug order on distributor for y8? (Esoterikos)
is that clockwise? Also where does it start that order?
Old 10-06-2003, 08:06 PM
chictunner97ex's Avatar
It goes...
1 3
2 4
In that order. if you need to, set your cam at TDC take off the cap to your distributor and look at where it is pointing to, and that would be your number one. good luck
Old 10-07-2003, 04:43 AM
SOHC_MShue's Avatar
Default Re: plug order on distributor for y8? (chictunner97ex)
thanx Yea i finally figured it out last night by looking at some old pics i found of my engine bay.
Old 10-10-2003, 02:22 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chictunner97ex &raquo;</TD></TR><TR><TD CLASS="quote">It goes...
1 3
2 4
In that order. if you need to, set your cam at TDC take off the cap to your distributor and look at where it is pointing to, and that would be your number one. good luck</TD></TR></TABLE>
3 4
1 2
punk
Old 10-10-2003, 03:23 PM
mts20k97's Avatar
poison is right
Old 10-10-2003, 03:47 PM
street dreams's Avatar
Location: chillin in that city called queen creek, but homes the atl
1 3
2 4
wrong please know what u are talking about first before u **** somebodys car up
Old 10-11-2003, 08:52 AM
SOHC_MShue's Avatar
Default Re: plug order on distributor for y8? (streetdreams02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams02 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong please know what u are talking about first before u **** somebodys car up</TD></TR></TABLE>
she was right guys
are you sure you were talking about a d16y8 poison?
Old 10-13-2003, 01:20 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
she was right guys
are you sure you were talking about a d16y8 poison?</TD></TR></TABLE>
yeah.
it depends too, both of ours are not *exactly* right, if you turn chictunner's numbers a little to the left and mine a little to the right since the distributor spark plug wire inputs are a little 'angled', 3 is mainly on top and 1 is towards the back.
Old 10-13-2003, 07:34 PM
SOHC_MShue's Avatar
Default Re: plug order on distributor for y8? (poison)
yea so i guess technically you both are kinda correct. I guess its just hard to write since they are angled. I guess 3 is an easier way of doing it.
2 4
Old 10-19-2003, 01:54 PM
i know i am right!!! the number one is about 10-11o'clock position but the damn order is right, so you men can go take a leap and be nice next time !!!
warfield21
04-15-2017 12:26 PM
taguchi09
06-11-2011 04:52 PM
h22a_junkie
04-11-2006 08:49 PM
Honda_18
11-27-2004 10:07 AM
SOHC_MShue
10-06-2003 10:05 AM
Quick Reply: plug order on distributor for y8?
