oxygen sensor wire diagram
Old 03-12-2004, 06:17 PM
IVI
IVI's Avatar
Default oxygen sensor wire diagram
does anyone have the wiring diagram for an oxygen sensor 4 wire? the wires out of my sensor somehow got pulled out of the connector and im not sure which wire goes where.
IVI is offline
Old 03-12-2004, 06:26 PM
IVI
IVI's Avatar
Default Re: oxygen sensor wire diagram (IVI)
its the sensor that plugs into the headers.
IVI is offline
Old 03-12-2004, 08:56 PM
onePOINTsix's Avatar
white wire is O2 Voltage (0-1V+), the 2 blacks need seperate grounds to most accurate, green need to be a swtiched 12V+ for the O2 heater
onePOINTsix is offline
Old 03-13-2004, 04:08 PM
IVI
IVI's Avatar
Default Re: oxygen sensor wire diagram (Sideout)
i need the diagram. what wire goes where into the connector?
IVI is offline
Old 03-13-2004, 05:57 PM
Kataku2K3's Avatar
Made it a really long time ago and have posted it many times, hope it helps. Ignore all the VTEC stuff, I was basically just showing a conversion. Good Luck
EDITED... LINK UPDATED
Modified by Kataku2K3 at 10:34 PM 9/12/2006
Kataku2K3 is offline
Old 03-13-2004, 06:52 PM
aw1234dude's Avatar
Default Re: oxygen sensor wire diagram (Kataku2K3)
That diagram freakin rocks man. Its times like these that I love to be a honda-tech member.
aw1234dude is offline
Old 03-13-2004, 07:59 PM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">white wire is O2 Voltage (0-1V+), the 2 blacks need seperate grounds to most accurate, green need to be a swtiched 12V+ for the O2 heater </TD></TR></TABLE>
That's only 1/4 of the way right. As my diagram shows you are correct in that the white is the reference output but the green is actually the ground for the entire sensor (ties into the TPS, ECT, IAT gnd.), while one of the blacks is a IGN 12V+ input for the oxygen sensor heater and the other is the ground trigger for the heater which is activated by the ECU.
Old 03-14-2004, 06:11 AM
IVI
IVI's Avatar
thats a great diagram, but i need it for the 4-wire oxygen sensor. i looked at my friends car yesterday on a lift and i saw that the top right is white the top left is green and the bottom two are black. which one is supposed to have the +12v? the bottom left or the bottom right? how can you check that the wires are properly connected? what will not having an oxygen sensor do besides making your car run richer?
IVI is offline
Old 03-14-2004, 09:31 AM
Qfactor's Avatar
ok here it is.
black wires are the heater element (you can hook them up either way)no directional polarity required
green is ground for the O2 sesnor
white is the signal
Qfactor is offline
Old 03-14-2004, 11:21 AM
IVI
IVI's Avatar
Default Re: oxygen sensor wire diagram (Qfactor)
k, can someone fill in the blanks on this and make sure the other 2 are right? thats what ive been trying to figure out.
http://ms0834.tripod.com/Untitled-2.jpg
Modified by IVI at 8:39 PM 3/14/2004
IVI is offline
Old 03-14-2004, 11:39 AM
Kataku2K3's Avatar
As Qfactor said, polarity for the oxygen sensor heater really doesn't matter but if you want to wire it up the way the factory does, and the way I always do. The black wire on the left (of your diagram) is the IGN 12V+ and the one to the right is the ground trigger which traces back to the ECU (A6).
Old 03-14-2004, 11:41 AM
IVI
IVI's Avatar
okay thank you. so the wire on the left should have +12v? and the one of the right is just a ground? but they're both for the sensor heater? is the white/green on my diagram correct?
IVI is offline
Old 03-14-2004, 01:17 PM
Kataku2K3's Avatar
Yea, you're diagram is fine and the one on the LEFT is a IGN 12V+ but the one on the <U>RIGHT</U> is not just any old ground, it has to trace back to pin A6 at the ECU (this way the ECU can regulate the heater). If you were to just ground the wire on the right to any old point your oxygen sensor heater would always be on (do NOT do this). Like we've said there really isn't any polarity so even if they are backwards it should still work but just to keep things organized I always do how I listed above. Good Luck
EDITED: because I wasn't thinking clearly...
Modified by Kataku2K3 at 7:19 PM 3/14/2004
Old 03-14-2004, 06:13 PM
IVI
IVI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">you're diagram is fine and the one on the LEFT is a IGN 12V+ but the one on the LEFT is not just any old ground</TD></TR></TABLE>do you mean the one on the RIGHT is not just any ground?
IVI is offline
Old 03-14-2004, 06:19 PM
Kataku2K3's Avatar
Yea, my bad. Just got to typing away, you know what i meant.
Old 03-14-2004, 06:20 PM
IVI
IVI's Avatar
ya i did, thanks. ill try it when it gets warmer out. its too cold to work on anything outside right now.
IVI is offline
Old 03-25-2004, 07:21 AM
IVI
IVI's Avatar
that diagram was actually not right. it was harder to do than i thought but i finally got it. ive made a diagram which is correct. here it is...
http://ms0834.tripod.com/o2wire.jpg
IVI is offline
Old 03-25-2004, 07:46 AM
Kataku2K3's Avatar
Can't see the pic. What wasn't right?
Old 03-25-2004, 10:29 AM
bo0sted's Avatar
I had same problem, im going to use the diagram tomorrow to see if it is correct.
bo0sted is offline
Old 03-27-2004, 04:47 AM
bo0sted's Avatar
Default Re: oxygen sensor wire diagram (MwGSR)
The diagram above is for the actual o2 sensor side. Does any one have a diagram for the wire harness side. I need this pretty badly.
bo0sted is offline
Powered By Garrett
02-17-2007 08:31 AM
B20VTI
06-27-2006 09:53 AM
eg6T
06-19-2006 05:08 PM
mf RENO
10-18-2004 02:25 PM
chethewitt
03-17-2003 05:54 PM
Quick Reply: oxygen sensor wire diagram
