oil weight and claarance?
oil weight and clearance?
I just checked the main bearing clearance's and they came out to .0020. If I was to build with the clearances I have what weight motor oil would be the best to use? Engine builders that have used these clearances please post And please no "this is too loose" answers. I am going to be FI and running around 18-20psi.
Modified by boost fed ls at 11:47 PM 3/23/2005
