Oil pump on ZC - liquid gasket or permatex grey ok?
Old 04-17-2005, 09:03 PM
TAG
TAG's Avatar
Default Oil pump on ZC - liquid gasket or permatex grey ok?
I removed my oil pump on my 92 DOHC ZC (blacktop) engine and am now putting it back onto the block. Helms for CRX says "Apply liquid gasket to the cylinder block mating surface of the oil pump" and they have a pic showing a dotted line where to apply it, etc.
I couldn't find "liquid gasket" online (googled) using the part number in the Helms.
I do have a tube of Permatex grey -- is this ok to use here?
Thanks
Old 04-17-2005, 09:59 PM
PrettyLude's Avatar
that should be ok to use, its almost comparable to hondabond
Old 04-17-2005, 10:01 PM
TAG
TAG's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">that should be ok to use, its almost comparable to hondabond</TD></TR></TABLE>
Great - thanks for the quick reply.
Do you guys think it's worth the $ to go buy some authentic hondabond? Or is my permatex grey just fine. Thanks
Old 04-18-2005, 07:08 AM
PrettyLude's Avatar
many people substitute permatex grey for it, but for a couple of dollars more you can have the hondabond, its up to you, both will work
Old 04-18-2005, 07:26 AM
TAG
TAG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">many people substitute permatex grey for it, but for a couple of dollars more you can have the hondabond, its up to you, both will work</TD></TR></TABLE>
Cool, good to know. Thanks
Mr. Prelude
04-24-2011 08:04 AM
EGR95
05-26-2009 06:47 PM
Inextricabledrvr
05-15-2009 08:03 PM
O16581724 5 2 5
06-23-2005 07:07 PM
Quick Reply: Oil pump on ZC - liquid gasket or permatex grey ok?
