Oil in my distributor
anyone have this problem? I had open it up and took everything out and there is a seal by the shaft,,,i tried acura dont have,,anyone have a part number for it and it is not the outer oring that hooks up the cam.I need the inner seal,,and lucky i did not burn my coil or igniter or cause a fire in my car.
Re: Oil in my distributor
You need a new dizzy. Although you can rebuild one I would not recommend it because trying to setup the pickups in the dizzy can be VERY frustrating/ time consuming. Just bite the bullet and buy a new one.
X2.... Just get a new one. Its possible though changing out that seal but then itll just give you a little headache. And plus a new will most likely last longer than a rebuilt one.
well it is giving me a head-ache but i just got done with my rebuild on my motor short on funds right now.Anyway i fixed the problem i found a seal on pro street online for 20$. Its very easy to put it back together btw.THANKS
Cody Pereira
13
05-13-2019 09:02 AM
