OEM or Aftermarket crankshaft?
What are the advantages/disadvantages of an aftermarket crankshaft over and OEM crankshaft? I can purchase an 89mm LS crank for $100 or an aftermarket 89mm crank for $700 +. What's the difference?
Re: (PrettyLude)
I'm looking at building a B18C5 block with an 89mm crank LS length rods and 85mm bore. I just can't see spending the extra $600 bucks for a scat (or other brand) crank when it seems as though I can get the same performance & reliability from an used LS crank. Am I correct in my thinking? Someong please tell me the advantage of going aftermarket.
Mad Scientist
Re: (THEUSED)
there is no advantage in going aftermarket; unless as sayd above you want a stroke not found in oem cranks.
personally i think nothing beats oem reliability.
89, 89mm, acura, advantage, aftermaket, aftermarket, b18c5, crankshaft, h22, h22a, honda, mm, nsx, oem, tech
