obd2 h22 p72 p1337 ckp usdm dizzy
ek civic w/ usdm obd2 h22a. im throwing code p1337. or crank position sensor high voltage using usdm obd2a p72. could this problem be coming from the obd2 dizzy? i need my car running with no engine light for emissions. i need help bad
Re: obd2 h22 p72 p1337 ckp usdm dizzy (SIBuddy)
diagnosis? i plugged a scanner into obd2 connector and read p1337. for crankposition sensor. the thing i dont get is if u unplug the crank sensor the engine will not start. therefor i dont know why it would be throwing a code because the engine runs
Re: obd2 h22 p72 p1337 ckp usdm dizzy (mudshuvelz)
It can ignore the sensor, just like if a CYP sensor in the distrib goes bad, the car will run. It just won't run as well as if you had a good sensor in there. It's a secondary OBDII sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mudshuvelz »</TD></TR><TR><TD CLASS="quote">the car runs and idles fine</TD></TR></TABLE>
I'm not saying it will run like poo, just that OBDII will be happier if it's fixed...
Re: obd2 h22 p72 p1337 ckp usdm dizzy (raene)
well that still makes no sense seeming that the ckp controls sequential fuel injection. if the ckp sensor dont work how would the ecu know when to tell the injectors to spray?
also does anyone know if the speed fluctuation and TDC combo sensor is the same for h22 as b-series?
CSHornet60
01-25-2007 05:54 PM
BorderM3
04-24-2005 11:35 AM
