OBD0-OBD1 Conversion, Crank but no start!?
Old 03-03-2013, 03:36 PM
Pancho2193's Avatar
Default OBD0-OBD1 Conversion, Crank but no start!?
So I went about and bought a p28 OBD1 ECU, an obd0-obd1 Conversion ECU harness, and a obd1 Distributor, hooked it all up and all I get is cranking and electrical stuff to go on but no SPARK!
Prior to this, the last person who swapped it had a JDM PR3 VTEC ECU ,so all the VTEC and O2 Sensors are plugged into the old OBD0 Harness, could this be my problem? Theres a bunch of wires spliced and cut from the original OBD0 Harness, should I just connect my ground wires, VTEC, o2 sensor directly using the extra wires that my jumper came with?
I'm running oBd0 MPFI on 88 Hatchback
Old 03-04-2013, 07:27 AM
Pancho2193's Avatar
Default Re: OBD0-OBD1 Conversion, Crank but no start!?
BUMP?
Old 03-04-2013, 02:47 PM
fcm
Old Fart
fcm's Avatar
Does the fuel pump prime? 94
Pancho2193
03-04-2013 05:33 AM
88zchatch
15
03-20-2009 12:06 PM
dem0nk1d
32
09-15-2007 11:49 PM
dbiker207
04-21-2007 10:23 PM
dbiker207
04-21-2007 10:23 PM
Quick Reply: OBD0-OBD1 Conversion, Crank but no start!?
