- obd0 ls/vtec dizzy q'z -
Old 08-10-2003, 02:17 AM
nevin's Avatar
Default - obd0 ls/vtec dizzy q'z -
If I want to do a ls/vtechk(y0!#) with my obd0 b18a will I need an obd0 b16 head and distributor? Or can I use an obd1+ head and distributor and it dosent matter? Or will my old distributor bolt up to a obd1+ head. Just wanna make sure before I buy somthing I cant use. Thanks
Old 08-10-2003, 03:12 AM
Fobtions's Avatar
Default Re: - obd0 ls/vtec dizzy q'z - (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">If I want to do a ls/vtechk(y0!#) with my obd0 b18a will I need an obd0 b16 head and distributor? Or can I use an obd1+ head and distributor and it dosent matter? Or will my old distributor bolt up to a obd1+ head. Just wanna make sure before I buy somthing I cant use. Thanks </TD></TR></TABLE>
u can use any obd b16 head, use a obd0 b16a distributor or chop the legs off and use a b18a distributor
Old 08-10-2003, 04:21 PM
nevin's Avatar
Default Re: - obd0 ls/vtec dizzy q'z - (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">
or chop the legs off and use a b18a distributor</TD></TR></TABLE>
chop the legs off? of my origional dist. im guessing you mean. So obd1+ distributors will not work on my setup?
Old 08-10-2003, 04:26 PM
Mad Scientist
mmuller's Avatar
if you have obd0 an obd1 dizzy wont work, as Fobtions sayd you can chop 2 legs of the ls dizzy
Old 08-10-2003, 05:21 PM
nevin's Avatar
Allright thanks guys. So with any 92+ b16 or gsr head I can use my origional distributor but I have to "chop off the legs"? Is there any hot to on the internet that shows this exactly?
Old 08-10-2003, 05:32 PM
Mad Scientist
mmuller's Avatar
Default Re: (nevin)
just test fit it and you'll see what you have to do
Old 08-10-2003, 08:34 PM
hondaR's Avatar
nevin i just bought a b16a obd 0 if you have the obd 1 distributer id glady trade it with you. i need the obd1 distributer
Old 08-11-2003, 02:01 AM
nevin's Avatar
I haven't bought anything yet. Just trying to figure out what I need to do this vtec head swap and not buy somthing I cant use. You bought an obd0 head and it woln't work on your obd1+ vehicle?
Old 08-14-2003, 07:02 PM
hondaR's Avatar
Default Re: (nevin)
no i bought a b16a engine and its obd0 but in orderfor it to work i need the obd1 distributer cause the tdc points arnt the same
Damills
11-07-2008 05:35 PM
ek_civic96
05-06-2008 12:58 AM
crxkidb16t
10-12-2005 11:19 AM
thegreatwhitehope
04-20-2004 05:26 AM
Quick Reply: - obd0 ls/vtec dizzy q'z -
