O2 sensor wire short macanic say have to replace trany and alternator - Honda-Tech
Old 08-07-2012, 02:47 PM   #1
Default O2 sensor wire short macanic say have to replace trany and alternator
Had the heat shield come off my 2002 Odyssey and broke the O2 wire took it to manic would not make it up the hill to the garage and then the battery is dead it starts off from stop real slow but once up to speed it is ok manic says that the alternator is not putting out any volts and the shift mod in the trany are not working it came up with error codes for trany not sure what they were now he tells me i need to replace/rebuild trany and replace alternator
Glatkinson is offline   Reply With Quote
Old 08-07-2012, 03:57 PM   #2
slowcivic2k's Avatar
Default Re: O2 sensor wire short macanic say have to replace trany and alternator
Came across this once before on a civic, the heat shield eats through the second O2 sensor, shorting the heater circuit, and blowing the ALT/SP SENSOR fuse, so that the alternator and speedo never work. You'll need to see if it shorted, and if so, what fuse it blew, they are probably related to some degree if they all occurred at the same time.
slowcivic2k is offline   Reply With Quote
Old 08-10-2012, 07:56 AM   #3
It is indeed just a blown fuse from the o2 sensor wire shorting to the metal. Repair/replace the o2 sensor wiring and change the fuse and your problem will be solved. Your alternator and transmission sensor is fine and does not need to be replaced.
ryan97civic is offline   Reply With Quote
B16A 96-00 swap HELP!!! jdmhondas4life Honda Civic / Del Sol (1992 - 2000) 9 04-30-2011 12:06 PM
89 4dr issues! Ls_Ef_Juggalo Honda CRX / EF Civic (1988 - 1991) 19 07-16-2008 12:01 AM
TRANSMISSION raviee Acura TL, RL & ZDX 5 03-27-2008 12:03 PM
ys1 speedo wiring? Nightfox Honda CRX / EF Civic (1988 - 1991) 8 11-20-2007 07:22 PM
what all tranies ? ty_racer Acura NSX 12 04-02-2004 11:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
