No brake lights - Honda-Tech
No brake lights
Old 09-29-2011, 09:00 PM   #1
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default No brake lights
Today I took the car out for a quick drive with a friend and he starts yelling "you have no brake lights!!" I'm like wtf... sure as ****.. no brake lights.
*I checked and replaced the fuse
*I bought a new brake switch under pedal
*Pulled all the bulbs and tested one by one
*Check hazard button it's plugged in still
*swapped some relays
Still I have nothing... Is there any other brake power source or brake switch? I know the brake light switch is a four wire connector so maybe something else is causing the issue. Where does the switch get the power from? Straight from the fuse box? Because I put a tester up to the switch and it didn't light up with any of the prongs I touched. But not sure if any of them should light it up. I would think they should though. Any ideas or thoughts?
I also have no hazards and I remember last week locking my car and having no horn when it locked.
I put a power tested to the fuse box on the fuse for brakes/horn and to the fuse for hazards and the tester doesn't light up. So why not... those aren't coming straight from the fuse box right... should the tester should light up saying there is power. So now I'm leaning towards somewhere there is a bad ground? but I don't even know where to start looking now... if thats the case...
I'm running out of ideas
Type-Spaz is offline   Reply With Quote
Old 09-29-2011, 10:27 PM   #2
DCFIVER's Avatar
Default Re: No brake lights
It'd be nice to know the MMY of the car....
DCFIVER is online now   Reply With Quote
Old 09-30-2011, 07:13 AM   #3
fcm
Old Fart
fcm's Avatar
Quote:
Ditto that. 94
fcm is offline   Reply With Quote
Old 09-30-2011, 06:41 PM   #4
DC5/EP3 MOD :)
Type-Spaz's Avatar
Oh sorry!!
Its a 2005 RSX-S
Old 09-30-2011, 07:23 PM   #5
90sedan's Avatar
Here's the etm schematic for the brake lights. It should be pretty straightforward. Make sure there isn't anything funky wired into the brake lights like a trailer hitch (not likely on an rsx).
Note: fuse 7 also controls the horn relay. There's a good chance that it's blown if your horn isn't working.
90sedan is offline   Reply With Quote
Old 10-02-2011, 10:37 AM   #6
DC5/EP3 MOD :)
Type-Spaz's Avatar
I think the fuse box itself went bad. . .
Old 10-02-2011, 02:25 PM   #7
DCFIVER's Avatar
Why?I didnt bother helping anymore after that last guy gave you the wiring diagram because I figured that was all you needed. I know you do most, if not all, of your own work. Whats the story so far?
Old 10-02-2011, 05:44 PM   #8
fcm
Old Fart
fcm's Avatar
I would also like to know why, is there no power at the fuse, is there no power on the white/green at the brake light switch, or are you just guessing? 94
*** The BASICS: No Start Diagnosis 101 *** juevi Honda Civic / Del Sol (1992 - 2000) 53 07-25-2016 08:35 AM
CRX no start, no power, good batt sxysweed Honda CRX / EF Civic (1988 - 1991) 8 02-06-2016 08:14 PM
Hazard lights not working but I got the turn signals to work. fourblades Honda Civic / Del Sol (1992 - 2000) 4 05-07-2015 10:18 PM
Fuse Replacement issue D16z6 93 SOL JonasG93 Tech / Misc 1 03-22-2015 09:15 AM
tach, horn, and gauge cluster power on lights don't work - what is common to all? baphomet Honda CRX / EF Civic (1988 - 1991) 10 02-15-2005 08:06 PM
Tags
brake, civic, dc5, drive, fuse, hazard, hazards, honda, horn, light, lights, odeyssey, power, rsx, switch, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
