New PCV valve causing high idle?
Old 06-22-2013, 03:05 PM
Zaraki's Avatar
Icon6 New PCV valve causing high idle?
I changed out my old PCV valve, when I took out the old one I shook it and could not hear it rattle. Probably clogged with oil and other crap from the years.
So I replaced it with a MKIV Supra Turbo PCV valve
(these are more efficient than the Honda ones and are popular with people running small boost set-ups and no catch can)
It was an easy replacement and the new valve fit perfectly.
However... I've noticed my idle will be anywhere from 1200-1600 RPM.
WTF???
Old 06-22-2013, 08:57 PM
hybridmiklo's Avatar
Default Re: New PCV valve causing high idle?
could most definately be the cause of the high idle. Each pcv valve is engineered for their application. They are calculated vacuum leaks in a way. Go get the pcv that is made for the engine. basically your creating a larger vacuum leak than originally designed.
Pekkaen
13
04-19-2007 04:04 AM
justint
01-15-2007 11:00 PM
k20rex
07-21-2006 02:19 AM
accordisslow
01-22-2006 08:27 PM
redex94
03-22-2005 10:28 AM
Quick Reply: New PCV valve causing high idle?
