Need a ball park cost of problem with my Honda PLEASE HELP
I took my car to a very good mechanic n my car has been over heating off n on n my serve engine light is going on n off I was told it is the computer n the car they put it on a machine n told me they couldn't re program it because Honda is the only 1 that noes the codes to the computer n the car , sense it's got to b reset n isn't programmed right its not transmitting to what the engine should do I need just a ball park figure on this I'm on a fixed income n a single mom
Re: Need a ball park cost of problem with my Honda PLEASE HELP
so..instead of asking the very good mechanic for a quoew..you signed up on a message board to ask strangers for a quote?
ok..ill bite..
tree fiddy plus tax
ok..ill bite..
tree fiddy plus tax
Old Fart
Ditto the above^^^ find another mechanic.
The ECU, [computer] has nothing to do with engine cooling, engine cooling is controlled by the water pump, thermostat, radiator and radiator fan, the ECU has no control over any of that.
What is the MM&Y of your car?
You said the over heating and CEL is "off and on", please explain.
As for cost, that depends on what is wrong, a CEL that goes on and off is normally related to emissions and that can be as simple as a loose or defective gas cap or as bad as a defective ECU, [computer].
Most shops will not charge more then half an hour labour to scan a car for trouble codes, to "reset" an ECU all you need to do is disconnect the batt. for 15 min. at the most. 94
Try Google or Yelp to find a "good mechanic" in your area.
