Need advice, 1cm scratch on cylinder wall; Hone entire cylinder?
Hello all, I'm in need of some advice.
I'm in the process of putting on another cylinder head to replace one with bent valves. Well, during the process I found a 1cm vertical scratch on the number 1 cylinder wall. The scratch is very faint and is very hard to see but I CAN barely catch it with my fingernail. I know something needs to be done about this but I'm unsure if I need to rehone the entire cylinder or is there something I can do about the scratch. It does NOT run the entire lenth of the cylinder wall, just 1 cm long about 1 inch down from the top of the block. Any input or advice on what I should do? Any help would be greatly appreciated, thanks.
Johnny
Johnny
Re: (1BadCvC)
If thats the case, should I hone all 4 cylinders and get new rings for them all? Or will doing one cylinder suffice? I mean I don't want to cheap out on something this critical but the labor to get this all done can add up.
Unless I can hone them myself... can anyone give me some tip on doing this? I've done swaps and head swaps and such, but I've never done an engine build before.
Re: (bb_one)
you prolly should re-hone and re-ring the block. As far as honing it yourself i dont think its too difficult but i just like leaving that up to my maching shop, just to ensure a good even hone.
Re: (1BadCvC)
Yea thats true. I plan on just bringing the block to a machine shop and have them hone it down.
How difficult is it to remove the pins from the pistons? Can I do this without a hydro press?
Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (1320JDMGSR)
im pretty sure you should get new rings when you hone the cylinders. Bc the old rings have set to the original hone and with a fresh hone you need fresh rings in order to get them to seat properly.
Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (1BadCvC)
General rule of thumb, always get new piston rings when you take the pistons out, the old ones wont seal anymore, even if you dont do anything to the block. Always new rings.
bb_one
04-14-2005 02:45 PM
