my car won't turn over and it's not the battery, *Please Help* - Honda-Tech
Old 02-28-2003, 02:19 PM   #1
junya16's Avatar
Default my car won't turn over and it's not the battery, *Please Help*
so last night i started driving my car and at about 3500 rpm's in first it felt like it wasn't gettin any fuel and was sluggish but ran ok the rest of the trip. then when i went to start it again it would turn over but even when i tryed to jump it it wouldn't start. now it just doesn't even turn over and i checked the fuel pump and line and they are ok and put a new battery in and that did nothing. any suggestions?
junya16 is offline   Reply With Quote
Old 02-28-2003, 03:16 PM   #2
tominos's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (junya16)
so it doesn't even crank? could be your starter, but that doesn't explain the sluggishness
tominos is offline   Reply With Quote
Old 02-28-2003, 03:26 PM   #3
Default Re: my car won't turn over and it's not the battery, *Please Help* (tominos)
i have to agree with the starter...
just hit it a couple of times and have someone inside try to start it to see if turns over.
pennies_hatchie is offline   Reply With Quote
Old 02-28-2003, 03:28 PM   #4
BangAccord's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (pennies_hatchie)
I also think it's the starter
BangAccord is offline   Reply With Quote
Old 02-28-2003, 03:53 PM   #5
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (BangAccord)
i tested the starter and it was fine, it cranked over fine last night and still no luck but today it's not even turning over and by the test the starter is supposedly ok.
Old 02-28-2003, 07:13 PM   #6
Dr. Gonzo's Avatar
Make sure all cabels to starter are tight...I recently changed my clutch and I didn't do what i just sugested. I had problems starting and it was all because the main power cable to the starter was loose.
-ben
Dr. Gonzo is offline   Reply With Quote
Old 02-28-2003, 07:14 PM   #7
All_Lag's Avatar
it could be a number of things
-Broken, loose or disconnected wiring to the starter
-Starter motor pinion jammed in flywheel ring gear
-Bad Ignition
-Starter pinion or flywheel teeth worn or broken
All_Lag is offline   Reply With Quote
Old 03-01-2003, 06:40 PM   #8
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (SlowSOHC)
it was the coil in the distributor, never would have guessed but glad to have it fixed
Old 03-01-2003, 07:50 PM   #9
did you ever test the battery or just going by the fact that it wouldnt start on the jum start... it might not have been giving enough power through the jump to start it ....
1SlowB16EF is offline   Reply With Quote
Old 03-01-2003, 08:30 PM   #10
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (1SlowB16EF)
the battery was bad but it would have worked if the coil would have been fine. but i got a new battery anyway
93 Accord SE Not Starting? bmorocks Honda Accord (1990 - 2002) 3 02-10-2015 11:00 PM
Starting/Battery???? ToledoLude Honda Prelude 3 03-21-2010 10:02 AM
HELP!! Problem starting in the morning after rain EK VTi Honda Civic / Del Sol (1992 - 2000) 4 10-20-2006 07:32 AM
Bad battery? Optima yellow top and weird electrical problems wreckedmyteg Acura Integra 14 04-20-2006 10:23 PM
My Integra won't start fbp_gizzer Tech / Misc 10 09-30-2002 11:22 AM
Tags
2002, battery, car, civic, crank, dodge, honda, okay, prevents, rains, starter, taurus, tuening, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
