replaced head gasket but b18 still running the same help!
Old 01-21-2010, 05:01 PM
fourdoorteg's Avatar
Default replaced head gasket but b18 still running the same help!
i changed my water pump and the timing was off when i put it back together when i started it up, it made a weird noise and smoke( i would compare it to a lit cigarette burning on its own) came from the passenger side near the tranny.
Anyways, i got the timing resolved and ran just fine for about 20 min. it then ran like **** and i found chocolate milk on the dipstick.
I changed the head gasket and the engine is still doing the same thing( runs for 20 min then barely idles) minus the smoke from the back. my compression numbers are 160 152 155 160. Please help me.
if the engine is cold or i let it sit for a few minutes. it will work fine again IDK help
Old 01-22-2010, 01:41 PM
Mikey3000's Avatar
Default Re: replaced head gasket but b18 still running the same help!
sounds like a problem with your fast idle thermo valve, totally unrelated to the work you did. i think there's a way to test that valve in accordance with the helms manual.
Old 01-22-2010, 01:48 PM
1992Si's Avatar
the oil....sounds like you have some water in there.
Why did you change the water pump ?
NZuercher
Engine Machining & Assembly
10
06-06-2015 08:42 PM
95ludeVTEC
11-10-2010 08:15 PM
Under Con. CrX
04-22-2007 08:27 AM
88civicHB703
09-10-2003 10:06 PM
EGTeK
07-28-2003 09:04 AM
Quick Reply: replaced head gasket but b18 still running the same help!
