metal shaving around axle - Honda-Tech
Old 03-13-2017, 08:47 AM   #1
Default metal shaving around axle
As title reads, I found some super fine metal shaving wrapped around inner most part axle (going into the transmission) like I ran over a tiny brill-o pad. Is my diff toast or maybe the teeth on cv axle itself? There weren't too many other signs of problems except I notice slight loss of power during boost. Its a turbo crx with a mf lsd. Of course the axle nut is stuck beyond belief, I tried a breaker bar with a 7' fence post attached to it and stood on it after I soaked it heated it etc. I couldn't get a good picture either. If anyone has a suggestion, thanks.
slagman is offline   Reply With Quote
Old 03-13-2017, 10:48 AM   #2
2x0
2x0's Avatar
Default Re: metal shaving around axle
I would think it would be difficult for metal shavings from the diff itself to get through the axle seal, unless your seal is also leaking a lot of fluid...
If seal is intact, then it's probably from the axle, or something else external to the transmission.
Drain the trans fluid and it should tell you if something is wrong inside.
2x0 is offline   Reply With Quote
Old 03-13-2017, 12:56 PM   #3
Calif_Kid's Avatar
Quote:
As far trying to remove the axle nut, when I need to do that, I just remove as much of the indentation on the nut as possible, and then use a 1/2" electric impact wrench, and it comes off OK. I use a torque wrench when attaching the nut, but the electric impact wrench to remove it. - Jim
Calif_Kid is offline   Reply With Quote
Old 03-13-2017, 04:37 PM   #4
Thanks, yeah I'm going to drain the gear oil again although I didn't see anything the first time. I did try an impact wrench. Maybe not enough psi. I saw a video on YouTube of a guy actually putting it in gear and giving it gas while the car was on ramps and breaker bar attached... The wheel pushes the wrench into the ground and pops the nut. Only if I'm real desperate I'll try that. Hate to have to buy a new knuckle.
Old 03-14-2017, 06:43 AM   #5
Calif_Kid's Avatar
Actually, when I said electric impact, I really meant battery powered - 1/2" Bosch. It takes a few seconds, but the nut does come off with it.
- Jim
Old 03-16-2017, 03:29 AM   #6
Ok so drain plug is totally clean, me thinks its the axle seal which looks completely shot. There must be some metal element in the seal. This may also be one of the reasons why I have so much oil everywhere and on the under body. looks like a metallic hairball
Best way to get metal shavings out of head eghatchfla Acura Integra 3 05-27-2011 11:12 AM
best way to get metal shavings out of piping jewjew bean Forced Induction 8 12-26-2006 07:32 PM
How to shave emblems off a DC2 bumper? B18ls*RAYON Welding / Fabrication 6 01-16-2005 07:58 PM
VTEC solenoid ? SLowCrx Honda Civic / Del Sol (1992 - 2000) 2 08-22-2004 09:05 PM
my intercooler has oil in it! TurbothisLS Forced Induction 9 09-13-2002 07:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
