Measuring O2 sensor voltage... - Honda-Tech
Old 08-31-2002, 11:44 PM   #1
Default Measuring O2 sensor voltage...
I have a 1-wire O2 sensor im trying to check. I know that volt range is between .1-.9 volts. What I need to know is how do I hook up a volt-meter to check it???
See Are X is offline   Reply With Quote
Old 09-01-2002, 12:40 AM   #2
tinkerbell's Avatar
Default Re: Measuring O2 sensor voltage... (See Are X)
get a volt meter (digital) and hook the black lead upto hte chassis or engine block and attach the red lead to the wire coming off the sensor...
t..
tinkerbell is offline   Reply With Quote
Old 09-01-2002, 08:14 AM   #3
Quick 200k Mile Motor's Avatar
voltage should be between 0.4xx - 0.6xx at idle
a little below 0.500 is perfect.
Quick 200k Mile Motor is offline   Reply With Quote
Old 09-01-2002, 11:48 AM   #4
Default Re: Measuring O2 sensor voltage... (Quick 200k Mile Motor)
ok thanks!
Old 09-01-2002, 04:14 PM   #5
tinkerbell's Avatar
um, in closed loop?!?!?
i think not,
the voltage should swing from rich to lean at idle once the ECU is in closed loop.
with the AVERAGE voltage being around 0.5v
t..
Old 09-01-2002, 09:17 PM   #6
Directly from the manual. "Warm engine to operating tempature. Unplug O2 sensor. Hook + lead to O2 and - lead to body ground. Hold engine at 4000 RPM for 30 seconds. Voltage should be .6v. Allow engine to idle. Voltage should have dropped below .4v when returning to idle."
HidPerf is offline   Reply With Quote
Old 09-02-2002, 08:22 AM   #7
Default Re: Measuring O2 sensor voltage... (HidPerf)
ive been runnig the o2 code since ive gotten my zc...ive tried everything to fix it..
anywayz my sensor reads .6v at 4k rpm but it takes like 2 minutes to go back down to like .49v
i think this is why im throwing the code...can someone tell my wats goin on..
zcivic91 is offline   Reply With Quote
Old 09-02-2002, 11:57 AM   #8
Default Re: Measuring O2 sensor voltage... (zcivic91)
Ok...I grounded the - probe, and put the + probe on the O2 Sensor wire...started up the car, waited a while, and nothings moving on the voltmeter...any ideas?
Old 09-02-2002, 06:15 PM   #9
tinkerbell's Avatar
are you using a digital volt meter?
have you waited 10 minutes for the O2 sensor to heat up to operating temprature?
t..
Old 09-03-2002, 03:41 PM   #10
Default Re: Measuring O2 sensor voltage... (tinkerbell)
i think not,
t..
Old 09-05-2002, 04:56 PM   #11
Do I have to use a digital volt meter?
Old 09-05-2002, 07:32 PM   #12
tinkerbell's Avatar
yes you do.
t..
Old 09-05-2002, 08:40 PM   #13
damn, I bought a analog one for nothing then...
1991 accord lx TPS specs? portlandkidd157 Honda Accord (1990 - 2002) 1 03-15-2011 08:18 PM
charging system problems 1997civicex Honda Civic / Del Sol (1992 - 2000) 3 04-23-2009 05:52 PM
Negative Volt Reading Question accord99power Honda Accord (1990 - 2002) 1 12-26-2008 05:51 PM
Volt meter running off o2 sensor for egt readings? Hybrid Forced Induction 11 07-04-2002 10:08 PM
o2 sensor voltage to check if engine is running lean/rich?? LS-G Tech / Misc 3 06-21-2002 09:11 PM
Tags
02, 200k, 89, civic, honda, measure, measuring, o2, oxygen, reading, sensor, sensors, single, voltage, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
