Limp mode but no CEL
Recently my b20b went into limp mode, but unfortunately there's no CEL so I can't read any codes. Car won't go pass 3500 rpm, changed injectors took it to pep boys and did a fuel cleansing and still the same. I reset my ecu couple times and still, can someone give me some hints on where to start looking could it just be my ecu that's fried?
Re: Limp mode but no CEL
Bump, did some research on why this would happen dizzy okay spark plugs are fine, wires, sensors everything seems to be fine, can't seem to figure out why it's in limp mode though
Thinking about getting a new ecu off eBay to see if that'll fix anything
limp mode with no codes usually means code 0, which means bad ecu. No codes is different than code 0 though.
To test for code zero, just check the codes the normal way by jumping the service connector with ignition on. If the CEL lights up solid, there are no codes. If the cel stays off, that means code 0.
