(Leakdown Test) Air coming out adjacent cylinder - Honda-Tech
Old 08-20-2007, 09:30 AM   #1
1 Fly SI's Avatar
Default (Leakdown Test) Air coming out adjacent cylinder
I did a leakdown test on my b16a. I put it at tdc and pressurized cyl 1, air came out cyl 2. Then I put cyl 2 at tdc and pressurized, air came from cyl 1. I thought it was a blown HG,so I pulled the head. The motor has arp headstuds and they were tight. The headgasket looks new. Could it be a warped head or something else?
TIA
-Thomas
1 Fly SI is offline   Reply With Quote
Old 08-20-2007, 09:39 AM   #2
thesmogman's Avatar
Default Re: (Leakdown Test) Air coming out adjacent cylinder (1 Fly SI)
I have seen heads that have dug out a pit in the head between cyl's.
Lay a straight edge on it and see if it is warped.
thesmogman is offline   Reply With Quote
Old 08-20-2007, 09:50 AM   #3
1 Fly SI's Avatar
Default Re: (Leakdown Test) Air coming out adjacent cylinder (thesmogman)
I already took it to the machine shop. I am going to have it decked. I just wanted more info to see if it could be something else. The head looked good also. No pits.
Someone here in town said cracked head,or bent valve, but I really don't see how it would do this.
Old 08-20-2007, 09:56 AM   #4
thesmogman's Avatar
Cracked yes. Valve no.
I guess we will know more in a bit. Huh.
Old 08-20-2007, 10:08 AM   #5
1 Fly SI's Avatar
Where could it be cracked to let air go from cyl to cyl? I don't know if I should have it vaccum tested or not?
Old 08-20-2007, 11:35 AM   #6
thesmogman's Avatar
It would have to be between combustion chamber to combustion chamber. Sometimes you can see it some not. But it can be repaired.
Take a look at the area that connects between the sleeves in the block. If it was the block it would be a cracked sleeve
Old 08-20-2007, 12:26 PM   #7
doubleA's Avatar
Either your head or block are not straight. But to me it sounds like a headgasket problem.
doubleA is offline   Reply With Quote
Old 08-20-2007, 01:25 PM   #8
TooManyTickets's Avatar
Default Re: (Leakdown Test) Air coming out adjacent cylinder (doubleA)
if you having the head decked you may as well finish the bit and resurface the block if u need to 100% sure
TooManyTickets is offline   Reply With Quote
Old 08-20-2007, 02:46 PM   #9
1 Fly SI's Avatar
Default Re: (Leakdown Test) Air coming out adjacent cylinder (TooManyTickets)
Thanks for the replies.The block is still in the car, I will try to get a straight edge soon. I looked at the head pretty good and didn't see anything, But it doesn't mean it isn't there. The cylinders look great. I thought it was a HG also but the thing is brand new looking.
Old 08-21-2007, 05:55 PM   #10
1 Fly SI's Avatar
Ok so they said it was straight and didn't need to be decked. They pressure tested it and vaccum tested it. Both came back with perfect results.
But I still don't under stand?
Old 08-22-2007, 05:11 PM   #11
1 Fly SI's Avatar
Old 08-23-2007, 09:32 AM   #12
cpl rampage's Avatar
Either a warped deck, sunk sleeves, or cracked sleeves, or a bad hg, but u said it looked good
cpl rampage is offline   Reply With Quote
Old 08-23-2007, 10:01 AM   #13
Default Re: (Leakdown Test) Air coming out adjacent cylinder (cpl rampage)
Check the deck on the block.
leaking compression from cyl 2 to cyl 1?? wayneDOHC Acura Integra 5 08-20-2013 01:03 PM
leaking compression from cyl 2 to cyl 1?? wayneDOHC Tech / Misc 0 08-12-2013 07:48 PM
leakdown test proceedure... blackeg Tech / Misc 5 09-20-2010 02:14 PM
Replaced Cylinder Head Leak Down BAD 2kblueintegra Acura Integra 10 09-15-2010 11:24 AM
compression and leakdown test results. stumped HulkSmash Tech / Misc 3 10-18-2003 04:48 PM
Tags
15, 55, adjacant, adjacent, air, ajacent, coming, cyl, cylinder, engine, ga, leak, leakdown, pressure, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
