intake mani swap--------is it necassary to replace all those o-rings on the injectors & fpr etc
I am changing my intake manifold with another stock one to minimize down time on a direct port install - I was looking through the helms and it says to replace all the o-rings and rubber stuff - is it necessary?
I was going to just replace the throttle body gasket and the intake mani gasket, is that sufficient? Should I change anything else, like:
1. injector o-ring
2. rubber ring on injector
3. seal ring on injector
4. iacv o-ring
5. fpr o-ring
TIA
1. injector o-ring
4. iacv o-ring
5. fpr o-ring
TIA
New User
Re: intake mani swap--------is it necassary to replace all those o-rings on the injectors & fpr etc
I'd just change the rest of that stuff if they look worn or damaged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL »</TD></TR><TR><TD CLASS="quote">I
1. injector o-ring
4. iacv o-ring
5. fpr o-ring
not necessary but you now have a good list of things to check for when the car runs shitty and idles real high.
1. injector o-ring
4. iacv o-ring
5. fpr o-ring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL »</TD></TR><TR><TD CLASS="quote">I guess I see how they look and go from there</TD></TR></TABLE>
just lube them all again. if they arent cracked or torn they should be fine
i would do the injector o rings, everything else should be fine...ive jsut had bad luck with injector o rings lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">just lube them all again. if they arent cracked or torn they should be fine</TD></TR></TABLE>Also make sure they haven't turned hard & brittle...
