installing cam gears
Old 10-22-2003, 08:45 PM
GT-KiLLa's Avatar
Default installing cam gears
how hard is it to install cam gears on a b-series engine? will there be much gain from it. i got a few hundred to spend, and was either thinking of cam gears or a lighter flywheel...any suggestions would help thanks!
Old 10-22-2003, 09:25 PM
vtecmike1's Avatar
Default Re: installing cam gears (GT-KiLLa)
cam gears with your mods would probably add some nice whp but a exedy 9.8 pound flywheel is a great mod that can be done for cheap around 250 or so.. its up to you but i have no regrets on my flywheel
Old 10-22-2003, 09:40 PM
Mad Scientist
mmuller's Avatar
Default Re: installing cam gears (vtecmike1)
you have your block decked and your head milled and no camgears?defenetely get cam gears and get them tunned...with your mods; more important than the flywheel.
Old 10-22-2003, 10:41 PM
GT-KiLLa's Avatar
how hard is it to install them? do i have to remove both of the cams?
Old 10-22-2003, 11:46 PM
*Bounty Hunter*
Mark's Avatar
Default Re: (GT-KiLLa)
http://www.c-speedracing.com has a nice how-to guide
Old 10-23-2003, 05:47 PM
GT-KiLLa's Avatar
Default Re: (94BlackCivicEX)
thanks thats a great link. but just wanted to know do i have to remove the entire camshaft in order to change the cam gears? can i just remove the valve cover and un bolt the cam gears off??? have anyone changed their cam gears?
Old 10-24-2003, 04:45 PM
GT-KiLLa's Avatar
up
Old 10-24-2003, 11:06 PM
Darth ModerVader
Padawan's Avatar
No need to remove the cams, but you will need to loosen the timing belt. Also keep in mind that you'll need dyno tuning to see any gains from adjustable cam sprockets - they aren't just a "bolt-on" part.
kpjo4
07-11-2009 06:44 AM
m R g S r
02-24-2006 02:05 PM
BLK99VTECR
06-01-2005 08:36 PM
Quick Reply: installing cam gears
