Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
Old 08-13-2003, 10:55 AM
caliriptide's Avatar
Default Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
Ok, I think I have the hookup on some injectors!!! SWEET! Heres the thing, the injectors are outta 5th gen/ Will they work in my 4th gen>??? I am running the P13, JDM H22 ECU. I did not know if the injectors would work. Ya know?/OBD1 , OBDII.
Thanx again!!
So can I get these injectors>??? for my prelude>?
H22 JDM 5SD
Old 08-13-2003, 11:47 AM
Austin's Avatar
Default Re: Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible (caliriptide)
97+ prelude injectors are 290cc/min the earlier ones were quite a bit more, the connectors are different, and their resistances are different.
Austin
Old 08-13-2003, 11:56 AM
Default Re: Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible (Austin)
> This will give some info of what I am face'n.
https://honda-tech.com/zerothread?id=589973
I have the H23 injectors, but I was told that it would run way lean/
What should I do>?
Old 08-16-2003, 07:28 AM
accordm3's Avatar
obd2 injectors will pump out about 10 less hp than obd1... obd1 pump out about 50 more cc's... plus to put the injectors in.. you owuld have to get a obdII wiring harness and splice them in
Old 08-16-2003, 11:18 AM
HotWheelz's Avatar
Default Re: (accordm3)
we did an h23vtec and guy had the stock 240cc injectors and when you plugged the p13 in it would run like ****.. just by swapping the injectors the car ran like a champ..
put the required injectors or run into problems.
caliprelude3087
09-02-2004 12:54 PM
se93
02-19-2002 08:36 AM
LSturboHB
01-03-2002 02:05 PM
Quick Reply: Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
