picked up a gsr block lookin to build it up looking 4 sum input (all motor)
Old 05-05-2003, 06:52 PM
riceboyEFsi's Avatar
Default picked up a gsr block lookin to build it up looking 4 sum input (all motor)
im basically using my crank which was still good from my b18c5 in my gsr block which i just picked after my b18c5 exploded im thinking of using using the ctr pistons on the gsr rods . Or should I go aftermarket. Im not looking to sleeve the block. Im still goona be using my b16 head w/ skunk internals including stage 2 cams . What kind of #'s will i be looking at in a 91 si hatch
Old 05-06-2003, 07:42 AM
Default Re: picked up a gsr block lookin to build it up looking 4 sum input (riceboyEFsi)
any1?
Old 05-06-2003, 07:54 AM
untitled's Avatar
ctr pistons, jun stg3 cams with fully upgraded valetrain, stroke the motor with b20 crank and bore it over a little. eagle rods are good and there pretty cheap. use skunk2 high comp valves. you might have clearence issues.
Old 05-06-2003, 08:22 AM
joe_bocc's Avatar
CTR pistons on ITR rods.
Old 05-06-2003, 10:13 AM
Default Re: picked up a gsr block lookin to build it up looking 4 sum input (88crx91integra)
well i got my skunks and i was very happy w/ them my head is all skunk and salvageable. I was thinking of using the ctr's w/ standard bore on gsr rods. What do u guys think
manoloek9
13
08-08-2010 06:36 PM
allmotorb16crx
13
12-27-2009 01:05 PM
chngeovr99
06-08-2006 06:17 PM
broketuner-Sol_Si
39
04-13-2006 06:37 PM
Quick Reply: picked up a gsr block lookin to build it up looking 4 sum input (all motor)
