IAC woes - Honda-Tech
IAC woes
Old 03-16-2017, 06:17 PM   #1
Default IAC woes
Hello All, wanted to runs something by you all to see if I am on track with my diagnoses with my idle issues. Engine is a B16A2, The engine idle bounces up and down, I have already set the TPS to 4.88 at rest, checked for vacuum leaks around the intake manifold with negative results. if i remove the intake and place my finger over the hole in the throttle body, upper right the idle smooths out to normal. once removal of my finger the idle returns back to bouncing around. Am I safe to say the problem is the IAC?
CCrown is offline   Reply With Quote
Old 03-16-2017, 06:30 PM   #2
pogeeboy27's Avatar
Default Re: IAC woes
Try cleaning the IAC with carb/brake cleaner.
pogeeboy27 is offline   Reply With Quote
Old 03-16-2017, 07:10 PM   #3
Hello failed to mention, I did go through the iac with cleaner, tested the connections to see if the solenoid trigger which it does, checked the gasket which turned out good and still experiencing the same issue.
01' SH M/T cold start idle issues cityjack Honda Prelude 1 01-01-2015 09:59 PM
wonky idle...replaced IdleAirControl already...what else to look for? The Chazzer Honda Element & CR-V 15 09-12-2012 04:24 AM
high idle charles1 Honda Prelude 17 03-20-2008 08:08 AM
Idle bounce hondaboy4life Tech / Misc 5 01-04-2008 07:22 AM
idle is bouncing whenever it feels like mistahmac Honda Civic / Del Sol (1992 - 2000) 10 08-29-2007 05:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
