I am almost done with my swap.
Okay, I forgot how much i got done last night, i know i went to bed at like 1:30, had to be up at 6:30.
So i went into the garage tonight and found this...
Still missing rear bracket and oil pickup.
I'll probably order them tomorrow.
1 Post
Re: I am almost done with my swap. (Plan B)
try getting a tripod, or proping the camera on something. that, and turn the exposure time down.
looks good from what you can make out
Re: I am almost done with my swap. (BluntMan)
Wow man looks amazing, I noticed your using the stock gsr manifold, what computer set-up are you using i.e-p28,72 etc? Did you remove the butterflies from the manifold?
Re: I am almost done with my swap. (hondaeg5)
Most all of the brackets and such are just painted high-temp aluminum.
Thanks for all the comments.
I plan on breaking it in with the stock intake manifold and a stock p28 ecu.
Then polished skunk 2 and chipped p28, for slightly less efficient/more agressive mapping.
Also, i plan on leaving the vacuum line off the actuator for the butterflies so it stays open all the time.
