howdo i fix my CEL?
howdo i fix my CEL?
i jumped my ecu and here are the results--
CODE 1-Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
CODE 6-ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
CODE 41-Primary Oxygen Sensor - Heater circuit malfunction
CODE 43-Fuel Supply System defective or malfunctioning fuel supply system
WOULD any of these 4 code be theresaon why i failed mssions
Re: howdo i fix my CEL? (wm5holla)
Yes, 3 of them maybe all 4. If you dont have properly functioning 02s they tell the ECU to dump a ton of fuel into the engine. So when both are not working it makes for bad emissions and bad mpg. The coolent temp.sen. will tell the engine when its @ opperating temp so it can adjust the A/F ratio properly.
Blaze
Blaze
Re: how do i fix my CEL? (wm5holla)
The coolant temperature sensor is for the ECU. There's a separate sensor for the gauge, they don't 'share' information.
The 2nd O2 sensor is probably located down in or near the cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">there is no sensor by my cat </TD></TR></TABLE>
oh yeah... I just noticed its a '92. I guess you only have the one oxygen sensor.
Hope it's similar to my 2 cars.
The engine coolant temperature sensor is near where the upper radiator hose attaches to the engine. 2-wires with a plastic plug, at least on my cars. There's a similar 'sensor' in the thermostat housing, which is at the lower radiator hose. That one's the fan switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">i jumped my ecu and here are the results--
WOULD any of these 4 code be theresaon why i failed mssions</TD></TR></TABLE>
why are you getting these codes in the first place? did recently perform an engine swap on your car and if you did what year is your car and the engin ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">92 si sohc vtec its an old motor!</TD></TR></TABLE>
92 Si civic with an Si engine, correct?
You car just started popping up with these codes one day outta the blue, eh ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">its not a b16 motor is a 92-95 si/ex(sohc vtec)</TD></TR></TABLE>
heh..ok...now answer my other question about the check engine light.
Your being vauge with your whole check engine light issue, this is why I'm asking for details. I'm trying to help you.
Re: howdo i fix my CEL? (Katman)
ever since i got the car the cel has been on.. my boy looked under my hood and saw that one of wires of the 02 sensor by the header was ripped in half. i thought if i get a new 02 sensor i would by good!. i traded some guy for a 02 sensor and the damn lite still came one. and i called ova my boy "SIC" and he jumped my ECU and the rest you know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">my boy looked under my hood and saw that one of wires of the 02 sensor by the header was ripped in half.</TD></TR></TABLE>
Was this damaged 02 wire on the 02 sensor side or on your engine harnesses side? And was the replaced 02 sensor a 4-wire 02 sensor?
Re: howdo i fix my CEL? (iam7head)
i got the code 43 on my obd1 d16z6. i first got it a few weeks after installing bosch universal o2 sensor on my aftermarket header. the sensor was moved to the collector from the primary exhaust runner. would the movement of the o2 sensor alone cause the code?? sorry to ask this in your thread, but it was kinda on topic and starting to get me angry
1. Please tell me you were being sarcastic when asking the question in bold?
2. Do you really want help or are you just messing around? You are extremely vauge with everything. I don't know if this is just how you normally communicate on a message board, or if you are just playing games.
95civicracer
11-21-2003 10:29 AM
