How screwed is my engine?
Long story short, my wife drove my 2000 Dodge Stratus 2.4 into a curb and busted the radiator. She drove it about 7 miles at 30-40 MPH until it lost power, started pinging, lost oil pressure and died. The next day, it cranks but has no compression and does not start. Did it blow the head gasket? What else could have been damaged? Should I put a $400 tested junkyard engine in or try to fix this one? I want to keep this car going. Thank you for your advice.
Homosexual by choice
Re: How screwed is my engine?
what do you mean by "no compression". Was an actual compression test done and what were the resulting PSI readings on each cyl? A junkyard motor would likely be the easiest fix, but it very well could not be totally destroyed either. The 420A and similar 2.4 Mopar engines are actually decent engines and pretty strong. Typically just driving it for a few minutes over heated will not catastrophically kill it. Also, how hard was the curb hit. Are you sure the radiator is the only thing that was damaged?
OnePointFive
05-04-2006 12:29 PM
mugenhatchie
04-03-2006 12:31 AM
KB Tuning
11-24-2004 07:31 AM
