How to Remove Broken Header Stud Bolt
New User
hopefully i used the right name there - the bolts/studs used to keep the exhaust manifold attached firmly to the block...one of these bolts is snapped off, how should I remove this to replace it....how is it set in there block? am i going to have to drill it out? Any help would be great. Thanks
Re: How to Remove Broken Header Stud Bolt (Ceeveek)
i had a bold stuck in the head and this is how i got it out...after spending forever tryin to drill it out with a bold extractor we...
grabed the drimel and put a cutting bit in it
cut a slit across the bolt wide enough to fit a flathead screwdriver
used a screwdriver to unscrew the bolt
it unscrewed really easy...like i said i did this to get a screw out of the head so i dont know if you have enough room to do this for the header but its worth a shot
New User
Re: How to Remove Broken Header Stud Bolt (TRENDSETTLER)
so you're saying the part of the bolt that is recessed into the head has a thread on it? it can be unscrewed?
I left mine in there, no big problemmo
Re: How to Remove Broken Header Stud Bolt (owen_the_soyboy)
Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Here's some pics:
always have the car warmed up when doign any kind of exhasut work. espcially on cast iron. loosen them with the car running , and then shut it off and remove them. on removeing it, I usually put in a center punch on the stud. Get is centered perfect. then dril it out to the TAP size of the hole then run a tap in there. It works really well, and is pretty fast. Get a 90Deg attachemnt for your drill for a hole like that.
Re: How to Remove Broken Header Stud Bolt (dwnthehatch)
you gotta love morons that love to put silicone everywhere ......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Re: How to Remove Broken Header Stud Bolt (Stripped Honda)
Omg to funny. Person should realize that the exhaust gasket can be reused. And you never use silicon except on a couple rubber gaskets (valve cover, oil pan, cam seals, ect..).
Here's some pics:
Talk about cheeseballin it! That would never fly with me!!! I guess thats why my stuff never leaks! I do it right the first time. He should have used THE RIGHT STUFF not red RTV. LOL
Here's some pics:
tensaiwung
27
03-28-2012 10:02 AM
