fuel system set up qustion(s)
Old 12-15-2010, 12:12 AM
Who the fack changed my title?!
sh!ft's Avatar
Default fuel system set up qustion(s)
so if i am running an walborol(spell check?) from the tank, then i steel braid a line with a filter to the rail, does the fuel press regulator run in between the filter and the tank or in between the filter and the rail?
also what is a typical suggested or recommended setup for a 500 hp turbo car? i already have the fuel rail, injectors, and the resistor box.
forgive me, i know certain things about cars, but not everything. thats why im asking.
Old 12-15-2010, 05:54 AM
fcm
Old Fart
fcm's Avatar
Default Re: fuel system set up qustion(s)
FPR between filter and rail.
Not sure I understand your second question, "recommended setup for a 500 hp turbo car"??? 94
Old 12-15-2010, 06:13 AM
habib's Avatar
What fuel are you goin to be using
Old 12-15-2010, 06:51 AM
em_at_kfi's Avatar
It's typically installed on the outlet side of the fuel rail.
If you have a PR valve with two inlets, you can run those anywhere between the pump and rail by flowing through both inlet ports.
http://kinsler.com/handbook154.html
eg:R
03-31-2010 05:37 PM
laziebun
02-13-2009 02:14 AM
2000BoostedEX
04-23-2003 08:40 PM
DubyaAye
01-07-2003 10:33 PM
dvp95
06-18-2002 10:09 AM
Quick Reply: fuel system set up qustion(s)
