how long do catalytic converters last?
Old 08-27-2005, 04:29 PM
pbink's Avatar
Default how long do catalytic converters last?
I'm getting a gnarly clicking/rattling sound during certain levels of acceleration as well as sense that my exhaust is getting blocked somehow...
How long do catalytic converters usually last? Is it dependent on mileage or lifespan, and what are some common symptoms of a bad/old cat?
Old 08-27-2005, 04:51 PM
G2 Speed's Avatar
Default Re: how long do catalytic converters last? (pbink)
i would assume mileage because... it filters the exaust gases that go threw..
Old 08-27-2005, 10:06 PM
2000psi's Avatar
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: how long do catalytic converters last? (G2 Speed)
pull the cat off and look through it to see if it's clogged...I've heard they will make a rotten egg smell when they go bad too, The cat should last at least 90K miles on an engine thats not tuned to run rich.
Old 08-28-2005, 11:25 AM
pbink's Avatar
Default Re: how long do catalytic converters last? (2000psi)
so no one's had a cat rattle on them?
Old 08-28-2005, 11:50 AM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbink &raquo;</TD></TR><TR><TD CLASS="quote">so no one's had a cat rattle on them?</TD></TR></TABLE>
If you cat is rattling then it a sign that you're running too lean of a condition(High Nox). Hence the reason the mounting pad inside the cat is melting off the honeycomb brick inside the cat which is why the cat has that rattling sound. It's tumbling all around the cat. Check camshaft timing and crank timing is within specs and not overtly advanced.
dayaftertomorrow
04-18-2005 07:51 AM
hYpE-R-29
08-21-2003 09:07 AM
lsteggy
04-15-2003 07:36 PM
JoshRambo
10-01-2001 02:31 PM
Quick Reply: how long do catalytic converters last?
