How long before gas goes bad? - Honda-Tech
Old 02-17-2004, 08:36 PM   #1
Propulsion's Avatar
Default How long before gas goes bad?
the car's been sitting for about 8month now, outside, although it rarely reaches the freezing point here in northern california.
Am I okay to just crank it up now? or should I look into draining the gas?
what causes gas to go bad and how long does it ususally take?
Propulsion is offline   Reply With Quote
Old 02-17-2004, 08:52 PM   #2
boostn420's Avatar
Default Re: How long before gas goes bad? (SilverCIVIC96)
Gas goes bad when it absorbs water. 8 months is probably ok. Just drive it to the gas station and top it off.
boostn420 is offline   Reply With Quote
Old 02-17-2004, 09:43 PM   #3
Brrraaaap!
Blaze45's Avatar
Default Re: How long before gas goes bad? (boostn420)
My buddy started up a Truck with 18 year old gas, an old 61 GM Truck, put in a batt and slapped on a carb 6 cranks and it fired up. I have started a Subaru with 5 year old gas in it. I know that supposedly it can go bad, but I sure havent had a problem yet.
just my .02 cents
Blaze
Blaze45 is offline   Reply With Quote
Old 02-18-2004, 06:57 AM   #4
Default Re: How long before gas goes bad? (Blaze45)
If you're at all worried, pick up a bottle of dry gas to put in before you start it.
Daemione is offline   Reply With Quote
Old 02-18-2004, 06:46 PM   #5
Propulsion's Avatar
Default Re: How long before gas goes bad? (Daemione)
what is dry gas?
Old 02-18-2004, 07:33 PM   #6
MightyMouseTech's Avatar
Actually, gas only lasts about 3 months before it starts forming deposits on everything it touches. The problem is worse in hotter climates because the lighter elements in the fuel evaporate and leave the heavier elements in the tank causing the fuels volatility to get very low.
Just drive over to the gas station and fill up as soon as possible. It will probably not run quite right until you have run a couple tanks of gas through it.
MightyMouseTech is offline   Reply With Quote
Old 02-19-2004, 02:01 PM   #7
Propulsion's Avatar
Default Re: How long before gas goes bad? (MightyMouseTech)
where would the fumes evaporate to? the gas tank is air-tight, and the vapor pressure would only build up to a equilibrium.
Old 02-20-2004, 09:08 AM   #8
haggar's Avatar
There isn't a specific point in time, like after 152 days, gas is bad.
Also, forming deposits/varnish is something else that happens, but not whats menat by gas going bad or stale.
Gas goes 'bad' when the more volatile compounds vaporize off.
See, fuel is blended to have a certain vapor pressure(measured in Reid Vapor Pressure, or RVP), that is a measure of how easily the gasoline will vaporize.
This is VERY important to the function of a car.
If you are in a hot climate, and/or a hot engine compartment, and the gas is too volatile, then it will vaporize in the lines, causing vapor lock. This isn't nearly as much of a problem, now that fuel pumps are pushing the fuel, instead of sucking the fuel like older mechanical pumps.
So, you want to make sure the fuel isn't too volatile, right?
Well, if its cold outside, and your engine is cold, then a fuel with low volatility will hit the cold intake manifold and condense into liquid fuel on the runners. And you don't start.
Here in michigan, it is common to have RVP of about 15 in the winter, and RVP of 9 or so in the summer.
If you filled your tank with summer gas, it might not run in the winter, and vice versa. I have a lawnmower very succeptable to this.
Going back to your question, as fuel gets older, especially if its in a warm area, the vapor pressure of the gas contantly gets lower, as the lighter compounds vaporize off. Your gas filler cap may be sealed, but you also have an evaporative emissions system, with a charcoal canister, and a purge valve. The gas tank IS vented, it leads tot he charcoal canister, which absorbs all the vaporized fuel, then sucks it back into the engine when the purse solenoid is activated.
So, the answer is totally: it depends..
You'd probably be able to run just fine with old gas, most cars compensate well. But you also might need to run a few things of fuel system cleaner through it all to help remove deposits.
(btw, sorry for the long response.. I'm bored at work, and used to work as a fuel system engineer working on evaporative emissions, so that was my cup of tea..)
haggar is offline   Reply With Quote
Old 02-20-2004, 10:13 AM   #9
tominos's Avatar
Default Re: How long before gas goes bad? (haggar)
wow, very detailed response. things i didn't know
tominos is offline   Reply With Quote
Old 02-21-2004, 08:36 AM   #10
Propulsion's Avatar
great response, thanks that explains where the vapors go. Ill try it w/ some additives and see how it works out.
thanks guys
Old 02-21-2004, 01:20 PM   #11
civickiller's Avatar
you can leave gas in there for a long time and it will work but it wont have the performace of new gas, like for example, say you fill your tank with 92 then let it sit for 4 years, dont put a motor in there and then boost it to 10psi and think its 92 octane so its all good. it loses its kick
civickiller is offline   Reply With Quote
Need Help Now! 95 LS No Start Condition jewfro Acura Integra 4 12-10-2010 03:16 PM
gas needle whoa'ss trevorjohn88ef Honda CRX / EF Civic (1988 - 1991) 7 02-04-2010 10:12 AM
Gas/Octane.. littleblue Honda Civic / Del Sol (1992 - 2000) 3 01-26-2006 03:34 PM
how do i siphon gas folta2169 Honda Civic / Del Sol (1992 - 2000) 9 08-28-2005 08:37 PM
Old gas? rasinhell Honda Civic / Del Sol (1992 - 2000) 10 05-15-2005 08:15 PM
Tags
bad, car, cars, fuel, gas, gasoline, gastank, good, long, navin, sitting, srt4, stale, tank, till
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
