How to jump the o2 sensor heater wire with a resistor??? - Honda-Tech
Old 09-20-2004, 08:58 AM   #1
JerseySiPOS's Avatar
Default How to jump the o2 sensor heater wire with a resistor???
i got a wideband and want to put in a 10W-25k resistor for the o2 sensor positive heater wire.
I have a 00 Si converted to OBD1, p28, but im putting the resistor in the obd2 harness o2 sensor heater wire.
The positive heater wire is C1
And the 2 grounds for the o2 sensor are C7 and C18.
Do i throw the resistor into the positive heater wire only,
or do i loop the positive heater wire and negative heater wire with a resistor??
Sorry, i did a search and couldnt find out the correct way.
thanks for any info.
JerseySiPOS is offline   Reply With Quote
1 Wire o2 sensor on 4 wire harness/ECU kevinoneill Tech / Misc 2 12-25-2010 02:05 PM
O2 circuitry shortage? Senior Taco Tech / Misc 7 01-28-2010 03:52 PM
need Help doing the resistor fix for the O2 CEL??? Turbo O Engine Management and Tuning 4 10-06-2008 04:26 PM
obd2 headache.. jayare05 Honda Civic / Del Sol (1992 - 2000) 4 05-17-2006 03:17 PM
4wire O2 sensor heater resistance. can I increase it? Bailhatch Tech / Misc 17 05-09-2005 07:59 AM
Tags
02, heater, honda, jump, jumper, jumping, o2, oxygen, positive, put, puting, resistor, sensor, sensors, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
