How to fix leaky oil drain plug???
Old 10-06-2002, 09:56 PM
justinCO's Avatar
Default How to fix leaky oil drain plug???
My stupid oil drain plug is leaking a little bit. Is there anyway to remedy this easily? Should I go get a new drain plug bolt and washer? Is there some kind of sealant that I can put on the threads or something to help seal the thing? Thanks...
Justin
Old 10-06-2002, 10:03 PM
TenaciousC's Avatar
Default Re: How to fix leaky oil drain plug??? (onetym408)
high temp RTV
Old 10-06-2002, 10:15 PM
Kamin's Avatar
Default Re: How to fix leaky oil drain plug??? (justinCO)
yea replace the washer
if you are too lazy to do that everytime you change your oil
just get some liquid gasket.
Old 10-06-2002, 10:19 PM
justinCO's Avatar
Default Re: How to fix leaky oil drain plug??? (KAMiN)
I guess I was too lazy to get a new washer this time. I just bought this '86 civic beater and just changed the oil real quick, hehe. I'll go get a new washer, and some liquid gasket just in case...oh and more oil
Thanks.
Justin
Old 10-07-2002, 03:00 AM
visi0n's Avatar
damn some of you like buying expensive stuff for your HONDAZZZ....
goto kragen and buy a 3-pack of drain plug washers for like $0.40 cents. you can buy some carbon stuff, rubbery stuff, or copper.
Old 10-07-2002, 09:14 AM
CXHatchback's Avatar
Default Re: How to fix leaky oil drain plug??? (visi0n)
Honda filters come with o-rings everytime.
Old 10-07-2002, 09:29 AM
advanracing62's Avatar
Default Re: How to fix leaky oil drain plug??? (CXHatchback)
helpful hint.... if you want to change your plug, but don't want to drain your oil. Take a shop vac and put the end so it just fits inside your oil fill cap. Turn her on and remove your drain plug. What's that??!?!! no oil comes out! what a good time for everyone, esp. if you are installing Spoon plugs. HTH!
Old 10-07-2002, 11:25 AM
New User
drumsy's Avatar
Default Re: How to fix leaky oil drain plug??? (advanracing62)
I stripped mine, so ended up buying an oversize, self-tapping plug from Advanced Auto Parts. Every oil change, I wrapt the plug in a couple layers of teflon tape, and use a nylong gasket. Works perfect for me!
Old 10-07-2002, 02:06 PM
CivicNewbie's Avatar
Default Re: How to fix leaky oil drain plug??? (drumsy)
Has anyone ever try the Frame (sp?) quick oil change kit? The kit has some sort of valve that replaces your oil plug. Wal Mart sells this kit for about $20.
Old 10-07-2002, 02:37 PM
keebler65's Avatar
Default Re: How to fix leaky oil drain plug??? (CivicNewbie)
i guess i wouldnt want to trust some valve that could leak without me knowing until its too late. its not that hard to turn a wrench. just my thoughts. this reminds me of the quick-brake-bleeder thing.
dwn2earth922
05-03-2007 08:30 PM
ahloung
14
03-14-2006 10:29 AM
infamousasian
05-31-2004 06:59 PM
Fooman
09-18-2001 07:29 PM
hybrid_eg
08-02-2001 08:31 PM
Quick Reply: How to fix leaky oil drain plug???
