how do you test a resistor box?
I'd like to make sure that the resistor boxs that I pulled from a junkyard still work well. How can I test them to make sure they still work good?
Re: how do you test a resistor box? (asianspeed)
Measure resistance over the input (yellow wire) and one of the output (red wires, doesn't matter which one) with an Ohmmeter... Peace
New User
Re: how do you test a resistor box? (Kataku2K3)
all you can do is do what he said and make sure that the electronics work and that electricity goes through the box.
Re: how do you test a resistor box? (misledyouth)
Make sure you have a good tester, if you have a cheap one then more then likly it will show nothing unless you have a good one. Since the resistance is so little.
[Modified by 90blackcrx, 4:17 PM 1/18/2003]
Re: how do you test a resistor box? (90blackcrx)
sorry to bring this back up, my resistor box has 1 red wire and four black, pulled from integra ls. I measures the resistance from the red to each of the black wires and its 6.1. What should it be? I have read that you could wire 10 ohm resistors inline. Should the resistors measure 10 ohms?
