How do I/can I de-pin harness connectors?
Long story short, I have 2 connectors that I need to use in a harness I'm making, but they've got like 22 gauge wires in them, and that won't carry the current. I also have a grip of other connectors that are the wrong configuration, but a larger wire gauge, big enough to carry the current. So what I want to do is de-pin both the correct and the incorrect connectors, then put the larger wires from the incorrect connectors into the correct connectors. VOILA!
Now, how do I get the wires and pins out of each connector without damaging anything? Any tips? Pics? Help? Thanks in advance.
Re: How do I/can I de-pin harness connectors? (i hate import cars)
A small flat tip screw driver will do, just undo the harness plug so it opens up and stick the flat tip tool into the wire entrance. I am not good at explaining this so pics might help, do a search on the net as I'm sure there are pics of this being done.
