How can I remove non broken exhaust manifold studs
Old 05-16-2014, 05:09 PM
thatcivic96's Avatar
Default How can I remove non broken exhaust manifold studs
I am replacing my header and downpipe tomorrow and I want to replace my studs also. I already broke the nuts loose and there are no broken studs. I have searched for articles on removing the studs but all I find is for broken ones. Also heard of the 2 nut on the stud method but not sure how it works. Thanks
Old 05-16-2014, 06:25 PM
F22Master's Avatar
Default Re: How can I remove non broken exhaust manifold studs
http://lmgtfy.com/?q=how+to+remove+a+stud&l=1
Old 05-16-2014, 06:29 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
you get two nuts,thread one on, thread the other on, tighten one against the other, and you have a bolt, this is basic mechanical stuff
Old 05-16-2014, 11:20 PM
Jcd5's Avatar
I just used a set of vice grips on the end of the stud where there is no thread
Old 05-17-2014, 03:02 PM
EFvtec Yo!'s Avatar
+1 for Vice Grips. You are replacing the studs so you don't have to worry about screwing up the threads. Clamp the vice grip on and go to town screwing them out. The double nut methods works well too.
Old 05-17-2014, 09:50 PM
fcm
Old Fart
fcm's Avatar
For the most stubborn studs, 2 nuts threaded/tightened together, with a closed end wrench on each nut, [close enough together to hold in one hand] tightening them, works on pretty much any stud.
Vice Grips are the first choice on broken/stripped studs if you do not have stud extractors. 94
sleepencivic
03-22-2011 06:39 PM
that_guy5
01-20-2010 02:15 PM
eg6REDmilano20
03-25-2009 02:26 PM
timmy0tool
10
12-19-2007 03:25 PM
95GSRTT
04-30-2005 05:57 PM
Quick Reply: How can I remove non broken exhaust manifold studs
