HELP! SCRATCHING SOUND WHEN STARTING CAR! - Honda-Tech
Old 02-07-2010, 02:20 PM   #1
awwsnap's Avatar
Default HELP! SCRATCHING SOUND WHEN STARTING CAR!
so i'm not completely sure if this is the correct thread for this issue but i need some help.
this morning when i went to turn on my car (05 honda civic ex sedan) it made a weak starting sound and then a scratching sound and then the engine cut off. when i tried to turn it on a second time, the car actually did end up cutting on although it sounded VERY WEAK.
i drove the car for a couple hours cause i was moving about today and the car itself during the drive was perfectly fine - nothing irregular. but then when i got home i shut it off and tried cutting it on again and the same thing happened. the car didn't cut on and i think this time the scratching sound was even louder. i tried a second time just like the last time though and once again it cut on although it sounded like it barely made it.
WHAT IS GOING ON??? o.O any thoughts?
awwsnap is offline   Reply With Quote
2000 Honda Passport seansmith Engine Management and Tuning 3 04-29-2011 08:13 AM
94 civic dx starting problem bale43kn Honda Civic / Del Sol (1992 - 2000) 2 04-29-2008 02:21 PM
Problem with my GSR!! d16vteceg Acura Integra 15 06-13-2006 07:28 PM
fuel problems rasta420 Honda CRX / EF Civic (1988 - 1991) 5 03-24-2003 10:20 PM
CRX won't start. Please Help. camera obscura Honda CRX / EF Civic (1988 - 1991) 7 03-14-2003 11:20 AM
Tags
2002, car, civic, engine, honda, make, makes, noise, scracthing, scratching, sound, sounds, start, starting, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
