HELP! new clutch, tranny and ITBs.... car won't run
the engine will turn over and over and over.....
but never fires up. any ideas?
i've quintuple check firing order and grounds. tried two different sets of spark plug wires... fuel pressure is 40psi... still nothing. the spark plugs are wet, so i know it's getting fuel.
all 4 cylinders are getting spark, i have verified it with the timing light
i know compression is good cause it was running perfectly before i installed the ITBs, and i didn't change the cam, or timing belt nor adjust them
it's kinda throwing a single firing of a cylinder immediatly after i start turning it over. it still just doesn't take tho.
ideas????
ideas????
ok, they're running
the throttle plates needed to be cracked open enought to send a voltage signal from the TPS to the ECU. i adjusted the screws, and it's running fine
mhcmm87
09-20-2018 07:03 AM
scotty.b16a1
12-31-2012 01:54 PM
Ek9_Cuhzz
58
01-07-2011 04:54 AM
