Help needed. B20 vtec swap. 4500 rpm idle. - Honda-Tech
Old 03-14-2017, 05:59 PM   #1
Default Help needed. B20 vtec swap. 4500 rpm idle.
So I just installed a B20 Vtec swap in my civic and I cannot figure out why it will only idle at 4500-5000 rpms. I believe that I have correctly installed the p28 chipped ecu and adapted my wiring harness to work with the obd2 system. If anyone has any ideas at all please let me know asap. Thanks.
Belial987 is offline   Reply With Quote
Old 03-15-2017, 01:33 PM   #2
I like the tuna here
DumpdEJ6's Avatar
Default Re: Help needed. B20 vtec swap. 4500 rpm idle.
My money is on vacuum leak.
DumpdEJ6 is offline   Reply With Quote
Old 03-15-2017, 01:51 PM   #3
Quote:
I plugged off the holes for the fast idle valve andit dropped to about 3000. I was also thinking a vacuum leak because that is the only thing that makes sense to me. I have 2 iac valves and it does the same with both of them. But I thought maybe the chipped ecu I bought on ebay may not be tuned correctly causing this issue.
Gsr b20v swap wont rev past 4500 Flipmonkey Tech / Misc 13 06-14-2015 10:21 PM
Gsr b20 swap wont rev past 4500 Flipmonkey Hybrid / Engine Swaps 2 05-25-2015 03:26 AM
96 accord limp mode? myaccord1993 Honda Accord (1990 - 2002) 18 01-12-2015 01:05 PM
GSR owners! Can you hear IAB at 5800? sebTeggy Acura Integra 11 02-22-2012 10:21 PM
VTEC enguagement and high idle questions .paul Honda Civic / Del Sol (1992 - 2000) 12 03-31-2003 08:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
