Help! Need firing order for '90 Civic 1.5L - Honda-Tech
Old 04-29-2002, 06:23 AM   #1
Default Help! Need firing order for '90 Civic 1.5L
I am helping my son rebuild his '90 Civic 1.5L. We realized last night that he had removed the plug wires without noting the firing order . Not sure what goes where. Can you help?
Thanks!
-Matt
Mattk is offline   Reply With Quote
Old 04-29-2002, 06:28 AM   #2
New User
Default Re: Help! Need firing order for '90 Civic 1.5L (Mattk)
firing order on 1.5 civic 1-3-4-2
on the dis 3 4
1 2
WICKED2 is offline   Reply With Quote
Old 04-29-2002, 06:43 AM   #3
WickedII. Not sure what the second line of your post means. Are you saying that the firing order is 1-3-4-2 but the order of the wires on the distributor is 3-4-1-2 ?
Sorry for my ignorance. I was thinking that the firing order was the order on the distributor??? Could I trouble you to provide additional clarification?
Thanks!
-Matt
Old 04-29-2002, 06:52 AM   #4
Thanks!
-Matt
If you look at the distributor, and starting with the upper left wire, moving clockwise, the order is 3-4-1-2. That's what Wicked means.
I just replaced my the wires yesterday and I can't confirm if that's correct...thank you short term memory.
Jesse H is offline   Reply With Quote
Old 04-29-2002, 07:11 AM   #5
Default Re: Help! Need firing order for '90 Civic 1.5L (Jesse H)
I think I have it!
On the distributor:
Upper left is 3
Upper right is 4
Lower left is 1
Lower right is 2
Firing order would then be 1-3-4-2!
Thanks!
[Modified by Mattk, 3:14 PM 4/29/2002]
Old 04-29-2002, 08:26 AM   #6
New User
u got it!
if u look at the dis. and reading it clockwise 3-4-2-1 but the firing order is 1-3-4-2
Fireing order on civic Eagle40 Honda Civic / Del Sol (1992 - 2000) 3 07-26-2007 04:11 PM
Firing order!!! mortificationrock Honda Civic / Del Sol (1992 - 2000) 10 05-22-2007 08:51 AM
fireing order ???? weazel967 Honda CRX / EF Civic (1988 - 1991) 3 09-14-2006 12:39 PM
My d15b8 will only fire on cylinders #3 and #4 wernhersey Honda Civic / Del Sol (1992 - 2000) 0 08-29-2006 05:47 PM
Firing order for d15b7 Ekay Jay Honda Civic / Del Sol (1992 - 2000) 4 01-23-2005 06:53 PM
Tags
15, 15l, 1992, 90, 91, cap, civic, distributor, distrubutor, firing, forum, honda, lx, motor, order, sequence
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
